AutoCAD 2010/2011/2012
Valued Contributor
rick.hberg
Message 1 of 2 (545 Views)
dimension text grip edit reduces line spacing
545 Views, 1 Replies
06-27-2011 05:12 PM
I've searched for this for a while now and found nothing, so I'm hoping maybe I am doing something wrong.  Thanks for any assistance.:smileyhappy:
If I place a dimension and have text above and below the dimension line (using \X), and then grip edit the dimension text to move it for space/clarity on plans, the text above and below the line will mysteriously move closer to the line.  If I have backgrounds applied to the text, which I normally do, the backgrounds will cover the line. Even without the background, it looks odd next to other dimensions that were not grip edited. Any Ideas? Thanks.
Civil 3D 2014
Windows 7 x64
Active Member
Jamie.Besso
Message 2 of 2 (382 Views)
Re: dimension text grip edit reduces line spacing
01-29-2013 09:37 AM in reply to: rick.hberg
Not exactly a solution but to get the text back to it's original position with proper spacing above and below dimension line:
Click on the text grip, right click then select RESET TEXT POSITION.
Unfortunately, if you move the text grip anywhere else the spacing gets messed up.
