AutoCAD 2010/2011/2012
Active Contributor
drc_ol
Message 1 of 19 (294 Views)
Dimension lines
294 Views, 18 Replies
02-20-2014 06:38 AM
I am having troubles with my dimensions lines. I am using blocks and dimension constraints
in objects with dimensions lines associates and grabbed by snap to this objects.
The problem is when i move my objects, everything follows unless the dimension lines who stays in their originals positions,
who is strange because regularly they follow the alterations made. Someone may know why?
David
pendean
Message 2 of 19 (271 Views)
Re: Dimension lines
02-20-2014 10:31 AM in reply to: drc_ol
A very basic question: are you using osnaps to 'snap' the dimensions to the objects?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
drc_ol
Message 3 of 19 (259 Views)
Re: Dimension lines
02-21-2014 12:24 AM in reply to: pendean
Yes, of course. I attach a really simple example to demonstrate what happens. What am i doing wrong?
I know it must be simple..
doni49
Message 4 of 19 (232 Views)
Re: Dimension lines
02-21-2014 07:35 AM in reply to: drc_ol
It appears that some points are not in fact snapped to any objects.  I think you need to double check that.
Notice in the top version you have a dim of 116 and in the bottom version it's 216?  The right dim line is snapped to the box and the left side is not.  The 392 and 502 dims aren't snapped to it either.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Active Contributor
drc_ol
Message 5 of 19 (227 Views)
Re: Dimension lines
02-21-2014 08:22 AM in reply to: doni49
They are snapped to the object ( midpoint in vertical), i just did that to see if it wasn't the fact of two dimension lines snapped in the same point was causing the problem. I put it again in the angle and the same happens ( top scheme).
Active Contributor
vivifira
Message 6 of 19 (218 Views)
Re: Dimension lines
02-21-2014 09:34 AM in reply to: drc_ol
I think you might want to look at the pad spacing for the dim. Look in the properities for vertical and horizontal spacing. I noticed the dead space between the 1 in 116 is about the same as the dead space for the 2 in 216. the only difference I see is that the 2 is wider than the 1.
pendean
Message 7 of 19 (210 Views)
Re: Dimension lines
02-21-2014 01:23 PM in reply to: drc_ol
Post a DWG file please, not a useless picture.
Active Contributor
drc_ol
Message 8 of 19 (203 Views)
Re: Dimension lines
02-24-2014 01:50 AM in reply to: pendean
I don't find this pad spacing in the properties of dimstyle. Could you be more specific?
I attached a .dwg file, but if you try this example in your Autocad the dimensions go along with the objects?
GrantsPirate
Message 9 of 19 (184 Views)
Re: Dimension lines
02-24-2014 09:11 AM in reply to: drc_ol
Turn ANNOMONITOR on by setting it to 2 (or pick the AM button at the bottom middle of your screen. If you see yellow warning symbols then you haven't snapped to the object and it is floating in space.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
JGerth
Message 10 of 19 (178 Views)
Re: Dimension lines
02-24-2014 09:40 AM in reply to: drc_ol
MIDPoint is a derived Osnap.  Generally speaking using Osnaps that tie to geometry features of an object (ENDPoint, NODe, CENter) are more reliable IME
