Can anyone shed any light on why my dimstyle appears different when I use different versions of AutoCAD.
In LT it is correct (left hand image), both styles are STANDARD font but in the full version (right hand image) the suffix text style is ROMANS.
Solved by bigroo284. Go to Solution.
DWG attached.
No warning messages appear & when you edit in ACAD it appears as STANDARD then reverts back to ROMANS once edit is completed.
I've solved it, I changed the Alternate Font File in the Options dialogue box & all's well again.
Thanks for your efforts.
