AutoCAD 2010/2011/2012
Active Contributor
weedseed85
Message 1 of 2 (186 Views)
Debuging my lisp
186 Views, 1 Replies
02-15-2013 01:13 AM
Dear Autocad / Lisp users,
Could somebody please help me with my lisp.
The main goal for the lisp is to correct all colors of the given layers.
And for a few exceptions I want to change the LineType and set them to ByLayer.
It works, most of the time. But it always gives errors.
Couls somebody please have a look?
(defun c:SLC8 ()
	(setq kleur 8)
	(ChangeLayerColor kleur)
(defun ChangeLayerColor (kleur / sset ename i)
	(vl-load-com)
	(setq i 0)
	(setq sset (ssget "X" '((8 . "AL*"))))
		(if sset
			(repeat (sslength sset)
				(setq ename (ssname sset i))
				(setq i (1+ i))
				(vla-put-color (vlax-ename->vla-object ename) kleur)
	(setvar "cmdecho" 0)
	(command "-layer" "unlock" "*" "")
	(command "layer" "c" "7" "0" "")
	(command "layer" "c" "7" "*AL70----*" "")
	(command "layer" "c" "1" "*AL-----_VLOERPLAAT" "")
	(command "layer" "c" "2" "*AL-----_SPARING" "")
	(command "layer" "c" "1" "*AL_MAATVOERING" "")
	(command "layer" "c" "8" "*AL31----*" "")
	(command "layer" "c" "8" "*AL32----*" "")
	(command "layer" "c" "8" "*AL21----*" "")
	(command "layer" "c" "8" "*AL22----*" "")
	(command "layer" "c" "8" "*AL_31----*" "")
	(command "layer" "c" "8" "*AL_32----*" "")
	(command "layer" "c" "8" "*AL_21----*" "")
	(command "layer" "c" "8" "*AL_22----*" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST012" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST018" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST025" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST035" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST050" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST070" "")
	(command "layer" "c" "8" "*AT$1A---_TEKST100" "")
	(command "layer" "c" "1" "ATT012*" "")
	(command "layer" "c" "1" "ATT018*" "")
	(command "layer" "c" "2" "ATT025*" "")
	(command "layer" "c" "3" "ATT035*" "")
	(command "layer" "c" "4" "ATT050*" "")
	(command "layer" "c" "5" "ATT070*" "")
	(command "layer" "c" "6" "ATT100*" "")
	(command "layer" "c" "254" "00ATT018*" "")
	(command "layer" "c" "254" "00ATT025*" "")
	(command "layer" "c" "254" "00ATT035*" "")
	(command "layer" "c" "254" "00ATT050*" "")
	(command "layer" "c" "254" "00ATT070*" "")
	(command "layer" "c" "254" "00ATT100*" "")
	(command "layer" "c" "254" "00KAD018*" "")
	(command "layer" "c" "254" "00KAD025*" "")
	(command "layer" "c" "254" "00KAD035*" "")
	(command "layer" "c" "254" "00KAD050*" "")
	(command "layer" "c" "254" "00KAD070*" "")
	(command "layer" "c" "254" "00KAD100*" "")
	(command "layer" "c" "254" "*BL$2----*" "")
	(command "layer" "c" "1" "*BL$3----*" "")
	(command "layer" "c" "254" "*BL$4----*" "")
	(command "layer" "c" "254" "*BL$5----*" "")
	(command "layer" "c" "254" "*BL$6----*" "")
	(command "layer" "c" "8" "*BL$7----*" "")
	(command "layer" "c" "8" "*BM$7----*" "")
	(command "layer" "c" "7" "*BL$9----*" "")
	(command "layer" "c" "7" "*FL80----" "")
	(command "layer" "c" "8" "*WL905---*" "")
	(command "layer" "c" "8" "*Xref*" "")
	(command "layer" "c" "8" "*BL$8----_TEKST*" "")
	(command "layer" "c" "8" "*BT$8----*" "")
	(command "SETBYLAYERMODE" "1" "")
	(command "clayer" "0")
	(command "SETBYLAYERMODE" "99" "")
	(command "layer" "c" "8" "*BL$7----*" "Ltype" "DASHDOT" "*BL$7----*" "")
	(command "._setbylayer" (ssget "X" (list (cons 8 "*BL$7----*"))) "" "yes" "yes")
	(if (tblsearch "LAYER" "BL$8----")
			(command "layer" "c" "1" "*BL$8----*" "Plot" "No" "BL$8----*" "" "")
	(princ "\nLaag BL$8---- Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "BL$8----Verdieping")
			(command "layer" "c" "1" "*BL$8----Verdieping*" "Plot" "No" "*BL$8----Verdieping*" "" "")
	(princ "\nLaag BL$8----Verdieping Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "FL------_BWS30")
		(progn
			(command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "yes" "yes" "")
			(command "layer" "c" "14" "*FL------_BWS30" "")
			(command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS30"))) "" "Front" "")
		(princ "\nLaag FL------_BWS30 Niet kunnen vinden")
	(princ)
	(if (tblsearch "LAYER" "FL------_BWS60")
		(progn
			(command "._setbylayer" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "yes" "yes" "")
			(command "layer" "c" "90" "*FL------_BWS60" "")
			(command "_draworder" (ssget "X" (list (cons 8 "FL------_BWS60"))) "" "Front" "")
		(princ "\nLaag FL------_BWS60 Niet kunnen vinden")
	(princ)
(princ)
Anny help will be great.
Thanks in advance.
Michel
Hello
Please could yo post in THIS forum :
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Bye, Patrice
braudpat
Message 2 of 2 (168 Views)
Re: Debuging my lisp
02-15-2013 02:51 AM in reply to: weedseed85
Hello
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
