AutoCAD Forum
data extraction-scale question
3 REPLIES 3
dannyshein
380 Views, 3 Replies
hello!
i get this strange message ( i have attached a pciture ) whule trying to use data extraction option in tools menu
in order to count blocks for electrical switch board plan.
in another computer with the same version of autocad i don't get this message for the same file.
is it counting the blocks correctly?
please help me.
thank you very much....
3 REPLIES 3
I always get that message, but as long as I don't use none-uniform scaled blocks it does not matter.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
thank you for your quick respond.
is there a way to make sure i don't use none-uniform scaled blocks?
and if i do use them - they won't be counted?
how can i turn this message off?
first of all, don't be too afraid from that message, it tells you exactly:
       Objects IN those blocks were not extracted
That does not mean that none-uniformly scaled blocks are not reported, only objects within them (I understand that as "block in block AND scaling none-uniform").
Not really, just be carefull during insertion of blocks, during scale-commands and when modifying properties in the property window.
don't know that sorry.
- alfred -
Alfred NESWADBA
”Boost
