Hi
I'm running an extraction. When I get to the preview I right click and select "Set Column Data Format" and select the format I require - Decimal 0.0 precision. But Autocad then ignores this and uses general. What am I doing wrong?
can you upload a drawing with the data you like to extract + the DXE file with the current settings for the export?
And to that data: which column is not correctly exported for you?
- alfred -
