AutoCAD Forum
Data extraction and organisation
3 REPLIES 3
ctnycc
373 Views, 3 Replies
Does anyone have any experience of the above?
I have a series of different lbocks in a drawing whihc i can manage to extract the numbers of each block, it is the next part i need help with where i want the count numbers for each type of block to appear beside that particular block, would this be in like a field ?
The blocks don't have attributes as i am just coutning the numbers of each.
Any help / suggestions would be appreciated on this
thanks
Colin
3 REPLIES 3
Patchy
in reply to: ctnycc
Use BCOUNT or you can use this handy dandy from Lee Mac
http://www.lee-mac.com/blockcounter.html
JoAnn_Hogan
in reply to: ctnycc
So let me get this correct. You want to count the number of blocks or you want to add the numbers in the blocks together?
Please see attachment
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
ctnycc
in reply to: Patchy
Thanks Patchy, lee macs did just the job.
”Boost
