AutoCAD Forum
custom tool bars
3 REPLIES 3
markmccree
239 Views, 3 Replies
custom tool bars
I am trying to load existing BMP files (button images) from 2004 version and the corresponding DWG files into the 2014 AUTOCAD LT version. Is there some fast way to do this??  I have tried to follow the help promts, but I am having trouble navigation the CUI menue.
3 REPLIES 3
bgingerich
in reply to: markmccree
Not sure how the images were accessed in 2004, but you can import them.
See if this recent thread helps at all:  http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Button-Images-on-Custom-Toolbar-do-not-disp...
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
markmccree
I got this now. In version 2004 you can edit the aclt menue file that directs the buttons and other related commands. I do not see this option under tools-- customize in the 2014 version. You can only edit the key command macros in that menue. i would like to speed this "button creation..pathing setup, but I may have to just do it one button at a time.
dgorsman
The CUIx system works like XREFs, but with commands instead of drawing entities.  In otherwords, you define the command once with the graphics, then the command can be added to the Ribbon, toolbars, menus, etc. and they will all be the same.  If the command macro, image, or so on changes you only need to change it one instead of every location.
”Boost
