AutoCAD Forum
Custom Paper size for PDF Plot
4 REPLIES 4
987 Views, 4 Replies
Hey All,
I am trying to creat a PDF of a file I need to send to someone to plot.  The paper size needs to be 220" long by 36" wide.  Everything I have tried I can not create or modify paper size to something this large.
PLEASE HELP!
4 REPLIES 4
steve216586
Easy, Go into the pdf properties and select custom paper size. Change to what you need and do a "Saveas". Close out and then in AutoCAD select the custom paper size you created and named.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
in reply to: steve216586
It will not let me make a paper size longer than 200 inches
So to clarify: you have an AutoCAD doc that is 220"x36". You have someone that needs to print off the 220"x36" document on one, unbroken sheet. They have a giant printer but they don't have a copy of AutoCAD. They want the file in a .pdf format because they do not own AutoCAD.
Please tell me if I've got this right.
If I do have this right, I would have them install a trial version of CAD or something like LT or some similar programs, to open up this single file and print it; or else, break the huge image down into 11x17 or 8.5x11 or 8.5x14 units and make into a multipage pdf, so they could print from a normal printer and reassemble on their desk.
*Jerrod Fehr (Production Manager/ Estimator)Cell: 204.296.3735Office:
204.878.9321Treads By Design Ltd.treadsbydesign.ca
”Boost
