Hello everyone,
For the past two weeks I am trying to create a custom Isometric (ISO) Linetype.
I'm working with Autocad 2012 and I've made a custom Complex Linetype like the "HOT_WATER_SUPPLY" line type.
But I cannot make it in an Isometric layer.
Is that even possible to make in a coordinate system?
Thanks so much guys.
Peter
Solved by dgorsman. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
I'm not sure what you mean by that. Do you want the text elements oblique relative to the direction of [for example] a Line, in order to look "right" in an isometric drawing? I think you would need to define a text Style to use in such linetypes, with the obliquing angle built into the Style, and in fact two of them, one obliqued at 30 degrees and one at -30. Unless I misunderstood....
Careful with the terminology - an "ISO" linetype usually refers to International Standards Organization (ISO), and in context metric drawing standards.
Hi Kent,
That is exactly what I meant. I haven't thought about making two linestyles with an obliquing angle.
I'm going to try that.
Thanks for your input!
