We have a custom cuix file that loads some pulldown menus nd ribbon tabs that we have located on the server so that it can be modified and automaticaly updates on all computers once autocad is closed and reopened. My problem is now when I make a change to my setup and save the file, it no longer updates on the other computers. ANy ideas why this is happening?
"...when I make a change to my setup and save the file..."
Just to get a little more detail, what sort(s) of change(s) are you making that do(es) not show up?
Changing the content only changes the content, it doesn't update the workspace (which defines what UI elements are shown). If your users have a personally defined workspace, addtional menus, Ribbon tabs, and Ribbon panels will not automatically be added to them.
We load a ciux file which adds a couple menu pull down items and also ribbon tabs for those who choose to use the newer interface and not the classic workspace. I discovered that the path for two of the pulldowns on a ribbon tab that I created was pathed incorrectly. I corrected the paths under the "Partial Customization Files" (See attached screenshot)and saved the changes.
Normally any changes that I make are reflected in every computer that has the cuix file loaded at startup. This did not take place this time on every other computer except my own.
Is this an Enterprise CUIx? If not have you considered using an Enterprise CUIx?
Cheers,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
"I discovered that the path for two of the pulldowns on a ribbon tab that I created was pathed incorrectly. I corrected the paths under the "Partial Customization Files"
I took this to mean that you have resolved the issue. Is there still an issue?
