AutoCAD 2010/2011/2012
3 Kudos
Post 1 of 8
Cursor is Laggy - Please Help :)
2905 Views, 7 Replies
05-15-2011 06:26 PM
Hi guys,
I'm using AutoCAD 2012 on ASUS WIN 7, i5, 4GB RAM, Intel HD Graphic Card.
For some reason my cursor becomes very laggy and jerky as I use the "Line" tool,
that being said, my cursor is completely fine when I use any other tool.
http://usa.autodesk.com/adsk/servlet...linkID=9240617
I know in the AutoDesk "Knowledge Base" there's a similar Q&A for my situation, but after doing carry out all the AutoCad commands the cursor is still laggy. I don't have a face scanner or virus program turned on. My drivers are updated as well.
So far, only "Line", "Polyline", and just about any function that involves drawing a line (eg: arc), my cursor becomes very laggy.
Seeing my laggy problem is isolated to "Line" function, I'm thinking my problem is not a hardware/software issue, but more of a setting problem.
Any help is greatly appreciated! Thank you!
Hey for anyone who's having the same problem,
change your windows to Basic!
Win 7, desktop, Personalize, Windows 7 Basic theme!
That'll solve the problem!
3 Kudos
Post 2 of 8
Re: Cursor is Laggy - Please Help :)
05-19-2011 11:47 AM in reply to: dulerong
New Member
0 Kudos
Post 3 of 8
06-01-2011 05:11 AM in reply to: dulerong
Thank you so much!!!
You totally made my day, I was already considering buying another computer.
:smileyvery-happy:
New Member
0 Kudos
Post 4 of 8
09-11-2011 03:30 PM in reply to: dulerong
Amazing!!! I was so irritated with this and this totally corrected it!!!
New Member
0 Kudos
Post 5 of 8
11-06-2011 08:03 AM in reply to: dulerong
I have been having the same problem and tried all these suggestions with little success.  Then as I searched within the program for every kind of grid or condition that my cursor could be snapping to.
I thought I would just type in "SNAP" into the command line.  Wouldn't you know it, but my cursor was set at a 1/16th inch grid and I could turn it off.  It has litterally been that easy the whole time.  I am surprised that isn't in Autocad's recommendations to resolve the problem.
Distinguished Contributor
4 Kudos
Post 6 of 8
08-31-2012 07:28 AM in reply to: dulerong
I am having this same issue with the cursor.  AutoCAD 2012 Mechanical.  I have tried every suggestion possible and nothing seems to be working, except at least in my case turning ORTHO off but I need having the ORTHO on to work. Here is what I have tried:
1- SELECTIONCYCLING - Off
2- Windows 7 Aero Themes - Off
3- Properties Palette - Off
4- Not using Bitlocker Feature
5- SNAP  on or off no effect
6- Nvidia Quadro FX 5800 driver update (in process)
Any other suggestions.
1,210 Kudos
Post 7 of 8
08-31-2012 09:04 AM in reply to: HJohn1
7- ROLLOVERTIPS
8- SELECTIONPREVIEW
- alfred -
Alfred NESWADBA
New Member
0 Kudos
Post 8 of 8
12-27-2014 10:08 AM in reply to: dulerong
yup that solved my problem, Thanks dude!
