Quick one here. Has anyone ever seen this situation.
I cannot open a 2010 formatted file in 2012 because it's corrupt (see attachement), but I can open it using 2014. Once open I save it back to 2010 format and try again to open it in 2012 but it won't.
Cheers,
Exfacto3.
Hello
Can you open in RECOVER Mode your DWG with an ACAD 2015 ?
And then purge & purge ...
Because 2015 has a better PURGE !
Patrice BRAUD
Your drawing was converted from microstation and sometimes getting tons of problems.
Try dxf format and dxfin with autocad.
(I opened it with 2012 no problem for me)
Your file opened right away in R2012: but you did not include the XREFs it wants, perhaps your problem file are those instead.
Your file was also bloated and littered with Proxy Objects: cleaned up and attached here.
Hello
Here is my version of your DWG (672 Kb) after SUPER Purge / SUPER Clean / SUPER etc
But please remind that you could same similar / different problems in any XREF DWG ...
Patrice BRAUD
