AutoCAD Forum
Corrupt DWG
9 REPLIES 9
Message 1 of 10
357 Views, 9 Replies
Corrupt DWG
Quick one here. Has anyone ever seen this situation.
I cannot open a 2010 formatted file in 2012 because it's corrupt (see attachement), but I can open it using 2014. Once open I save it back to 2010 format and try again to open it in 2012 but it won't.
Cheers,
Exfacto3.
9 REPLIES 9
Message 2 of 10
braudpat
Hello
Can you open in RECOVER Mode your DWG with an ACAD 2015 ?
And then purge & purge ...
Because 2015 has a better PURGE !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 10
pendean
Can you share this file here? Most of us have 2012.
Message 4 of 10
in reply to: braudpat
Recover didnt work.
Message 5 of 10
in reply to: pendean
Here is the file.
Message 6 of 10
Patchy
After open it, use AUDIT (3 errors)
Message 7 of 10
in reply to: Patchy
So were you able to open it with 2012?
I just tried to open your version and got the same old error:(
Message 8 of 10
Patchy
Your drawing was converted from microstation and sometimes getting tons of problems.
Try dxf format and dxfin with autocad.
(I opened it with 2012 no problem for me)
Message 9 of 10
pendean
Your file opened right away in R2012: but you did not include the XREFs it wants, perhaps your problem file are those instead.
PG046-002-PMP-0500-01.dwg
Your file was also bloated and littered with Proxy Objects: cleaned up and attached here.
Message 10 of 10
braudpat
Hello
Here is my version of your DWG (672 Kb) after SUPER Purge / SUPER Clean / SUPER etc
But please remind that you could same similar / different problems in any XREF DWG ...
Patrice BRAUD
”Boost
