AutoCAD 2010/2011/2012
ryan0416
Message 1 of 6 (846 Views)
Copy with base point problems
846 Views, 5 Replies
07-09-2012 02:06 PM
When I use the copy with base point command in paper space and try to paste it into paper space of another drawing it seems to come in on a different axis or something. I can see the view ports as they are supposed to be however the text just shows as a line. It would be as if I were to put text in model space on top view and see it just fine then go to a front view and see just a line. Does this make sense? Has anyone found a solution to this problem?
pendean
Message 2 of 6 (841 Views)
Re: Copy with base point problems
07-09-2012 02:37 PM in reply to: ryan0416
What are UCS and PLAN set to in both drawings?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
ryan0416
Message 3 of 6 (839 Views)
07-09-2012 02:43 PM in reply to: pendean
UCS is set to World in both drawings. Not sure what the Plan is where would I look for that?
Thanks for you reply!
pendean
Message 4 of 6 (826 Views)
07-10-2012 05:02 AM in reply to: ryan0416
PLAN could be set to WORLD as well in both files, to match your UCS.
ryan0416
Message 5 of 6 (814 Views)
07-10-2012 08:47 AM in reply to: pendean
The "Plan" command is only valid in model space. I am trying to get paper space text and dimensions to copy over to another drawing. Would the plan setting in model space some how effect my paper space? Both plan and UCS are set to world currently.
ryan0416
Message 6 of 6 (811 Views)
07-10-2012 08:49 AM in reply to: ryan0416
Somehow everything is working fine today and I have changed nothing. Must have been a glitch in autocad. Have you run accross this issue before?
