I've read all the threads listed for the above, and pursued all the solutions, nothing worked. I'm amazed Autodesk hasnt issued a statement and fix for this.
@Anonymous wrote:I've read all the threads listed for the above, and pursued all the solutions, nothing worked. I'm amazed Autodesk hasnt issued a statement and fix for this.
Come here just to complain? Must have because you have provided practically no information related to your issue; exact version of your software, service pack, OS, RAM, all dwg's or just one, etc.
just one drawing, autocad 2012, windows 7 64 bit. I found that a variety of strange looking lines in the workspace are the cause, if I dont use them, all is ok. Once corrupted, removing the line-types doesnt revert to useable.
You are 3 versions behind the current one. If the SPs for 2012 didn't fix it, then it will not be fixed in your version.
Not sure what you mean by "statement".
@Anonymous wrote:just one drawing, autocad 2012, windows 7 64 bit. I found that a variety of strange looking lines in the workspace are the cause, if I dont use them, all is ok. Once corrupted, removing the line-types doesnt revert to useable.
If it's just one drawing, how in the world could you expect ADSK to fix this? Did you consider that maybe it's just your drawing that's messed up, not ACAD? Drawings get corrupted frequently; move on.
