We have been getting a "Copy to Clipboard Failed" error just as everyone else has. We now have had a drawing file that gets the error on one machine, but doesn't on another. I have tried all of the other tips and tricks posted in the other posts(audit+purge+save, export to R12.dxf, etc). I have no problems on the machine that I use. However there are a couple of machines that get the error.
Has a resolution bee resolved for this "bug"?
Any other suggestions?
Machine that works:
AutoCAD 2012 (Autodesk Product Design Suite Premium 2012)
Autocad Mechanical SP2 installed.
Intel Core i7-2600 CPU @ 3.40 ghz
16 GB memory
Windows 7 Pro, 64 bit OS, SP 1
One of the Machines that has the error:
Intel Core i7-3770 CPU @ 3.40 ghz
16 GB memory
@pendean wrote:
So the problem is one file? For now, yes. But it has happend to other files before.
You installed a package, with verticals: was this file from one of those verticals? Or saved by one? No, it was created with the AutoCAD .
Do both machines have all the software? Yes.
if you open the file in the other AutoCAD variants in the package does the problem go away? I have only tried to open the file in AutoCAD. As stated, one machine wil copy to the clipboard correctley, I have two that will not.
Please see above..
FYI..........
This is not the first time we have experienced this issue. We have had this to happen numereous times, on any different machines, (40+ workstaions in this location)
@pendean wrote:
You need to drill deeper: only using AutoCAD when you have a package with other variants is not a good way to try to identify the problem.
I'm confussed. Please explain. Should I have opened the file with Inventor? Mechanical?. I thought comparing apples to apples would have been testing with AutoCAD?
@pendean wrote:
Or post the cuklprit DWG file here and point to the objects that cannot be COPYCLIP and PASTECLIP for others to try.
When I try to upload the dwg, I get the following error: The contents of the attachment doesn't match its file type.
Please advise.
OK...tried again. Still can't upload dwg.
OK....I'll try again.
Still can't get it to upload.
I'll try to upload from another source later this afternoon.
Dean;
Web site is telling me that the post is being successful, but no file seems to be uploaded. Is there anything blocking me on Autodesk's end from uploading the file, even a compressed or zipped file?
Please see this FAQ about attachments. If your file meets these requirements reply back with browser info
Discussion_Admin
1) Internet Explore 9.0.8112.16421, update 9.0.19 (KB2862772)
2) I deleted everything except the areas that are in question, and purged it to get it under 1.5 mb. I also zipped the file. Still will not upload.
Attachment add by
Discussion_Admin
I take it you're still having issues attaching the file if so please send it to moderator@autodesk.com
What browser are you using?
Discussion_Admin
Has a resolution been found for the Copy to Clipboard issue, other than savinging it down to a AutoCAD R12 dxf file?
Have been seeing this error lately.
I opened a new drawing, inserted the drawing that is giving the error message. Check the "Explode" check box and it has been working for me.
Hope it helps!
JM
good new Rocky i think i found a solution to your issue. it has to do with proxy objects, probably from importing step files or exporting from inventor. if you run the lisp found at http://www.cadstudio.cz/en/download.asp?file=DelProxy all proxy objects will be removed and your dynamic blocks should remain intact. it has worked for a few people here with good results but cant say that it is 100% bullet proof yet.
Let me know if this works for you if you ever run across this again.
Matt
