Has a fix or resolution been found for the "Copy to Clip Board Failed" error. I am seeing it pop up again, with trying to copy AutoCAD Dynamic Blocks, cut and pasting them from one drawing to another. I have read the post stating to export to a R12 .dxf, but that loses the Dynamic Block capabilities.
Just wondering.
Moderator;
If this post needs to be moved to another forum, please do so.
Thanks.
Dean;
Attached are two files that were in question. I only sent the views that would not copy clip.
Process:
1) Files were created on Machine "a" and saved to a server.
2) Files wer opened by Machine "b" from the server.
3) views were selected anc CTRL-C for copy.
4) new drawing opened from .dwt on server.
5) Tried to CTRL-V to paste and got the Copy clip error.
6) REPEATED the same process on Machine "c" with the same results.
Machine "a" can copy and paste frome one drawing to another with no problems.
The two Dynamic Blocks embedded in Test2.dwg (yellow amd magenta in color), will not let you select a visability state.
Oops! forgot to add second drawing.
Thanks for looking at the files.
Do you know what causes the issue? Is it something off the normal? Is it a setting/variable that needs to be set? I've seen some weird things over the years and this one seems to be the weirdest.
As far as the two blocks having the same name, I thought dynamic blocks had the same name but different instances. Or am I mistaken?
I know you said that you had no problems. On some of our machines, we have no problems. But other machines we do. It always seems to be connected with some dynamic block. All of our machines are setup the same way, with the exception of workspaces.
FYi......
Autodesk Product Design Suite Premium 2012
Version F.205.0.0 AutoCAD Mechanical 2012 SP2
Win 7Pro, 64 Bit SP1
