AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 5
copy block definition and assign
1099 Views, 4 Replies
05-29-2012 08:42 AM
Just began using CAD 2010
Can anyone tell me where "copy block definition and assign" resides?
in 2008 it was a right click item when a block is selected
That was very quick and useful
It appears now this command is a very cumbersome chore involving the block editor-which for my use is a real time-waster
Any assitance would be appeciated!
Stella
*Expert Elite*
594 Kudos
Post 2 of 5
Re: copy block definition and assign
05-29-2012 09:18 AM in reply to: stelladujnic6505
Make a shortcut command in Acad.pgp
It will work fine.
Active Member
1 Kudo
Post 3 of 5
05-29-2012 10:50 AM in reply to: stelladujnic6505
I would also like to be able to do this, but I don't understand your reply Patchy.
Could you give more detail?
Thanks!
*Expert Elite*
594 Kudos
Post 4 of 5
05-29-2012 11:51 AM in reply to: avoc42
I hardly use this feature so I'm not going to customize the CUI.
What I suggested to do was adding a shortcut key in ACAD.PGP (either open it and edit or use command alias editor in EXPRESS)
And to use it, type in CBD
*Pro
169 Kudos
Post 5 of 5
05-29-2012 12:42 PM in reply to: Patchy
I believe that command is not part of vanilla AutoCAD. Here's an alternative.  After loading the lisp, use the CUI to it to the right-click context sensitive menu for blocks if desired.
http://www.lee-mac.com/copyblock.html
Post to the Community
New Post
