AutoCAD 2010/2011/2012
Distinguished Contributor
OZRevit
Message 1 of 11 (2,787 Views)
Copy and Increment text
2787 Views, 10 Replies
08-21-2012 03:06 PM
Hi, Does AutoCAD have a function to copy and increment text? Say I have a piece of text that says Area 1, I want to copy this text a number of times so that I get Area2, Area3, Area4 by just copying ....
Many Thanks
Active Contributor
W2CAD
Message 2 of 11 (2,783 Views)
Re: Copy and Increment text
08-21-2012 03:26 PM in reply to: OZRevit
TCount, an AutoCAD Express Tool will do that for you. Basically, the procedure is to place the common text (Area) where you want it. Then type TCount and select each text entity in the order that you want them numbered. You can then decide the starting number and increment as well as whether the number will be a prefix or a suffix.
Autodesk AutoCAD 2014 Certified Professional
OZRevit
Message 3 of 11 (2,779 Views)
08-21-2012 03:43 PM in reply to: OZRevit
Thanks for the reply...but what  I'm hoping to do is to place the word Area1 just once, then copy and increment it multiple times, so when I copy it, it becomes Area2, Area3 and so on...I can't get this to work with tcount
*Expert Elite*
Patchy
Message 4 of 11 (2,775 Views)
08-21-2012 04:57 PM in reply to: OZRevit
Lee MAc Programming, google it. He has it.
OZRevit
Message 5 of 11 (2,772 Views)
08-21-2012 05:04 PM in reply to: OZRevit
hmmm...this has been a standard feature in Microstation for very long time (V5 as far as I remember in the mid 90s)
Thanks again
*Expert Elite*
Patchy
Message 6 of 11 (2,767 Views)
08-21-2012 05:57 PM in reply to: OZRevit
Yup, and so many years after Autocad was born, we still can not draw double curve lines or have a double lines with one continuous and a dashed like highway paint marking. $4,000 program :smileyfrustrated:
*Expert Elite*
Alfred.NESWADBA
Message 7 of 11 (2,756 Views)
08-21-2012 11:04 PM in reply to: Patchy
You are right for arcs combined with double lines. But straight multiple lines with different linetypes work with _MLINE.
MLINE is not a favorite command for me, but for some few cases it does it's work (with limitations, ok).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
Patchy
Message 8 of 11 (2,749 Views)
08-22-2012 01:11 AM in reply to: Alfred.NESWADBA
Curve them, that's what I want .
*Expert Elite*
3wood
Message 9 of 11 (2,746 Views)
08-22-2012 03:37 AM in reply to: OZRevit
Search for INNB or ALTEXT.
imadhabash
Message 10 of 11 (2,741 Views)
08-22-2012 04:14 AM in reply to: OZRevit
your need exactly here (attachment) ...i use it from years ago. it's great and power..
just appload it.
i hope it's help
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
Need installation help?
