As the above mentioned, I have a drawing drawn using polylines with width from someone. The width of the line are suppose to represent area,
To put things into prospective, here is an example:
The polyline is 10 unit long and with a width of 2 unit wide. If i explode that polyline, it will become a single polyline without width. The line are suppose to represent 10 unit long and 2 unit wide; representing an area.
My question is is there a way to change the line above directly from polyline with width to a close polyline (4 x polylines) of 10 unit long and 2 unit wide. Thank you.
Use command FLATTEN and choose Yes
or go here and get the autolisp: http://cadtips.cadalyst.com/linear-objects/polyline-outline
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Hi
I think I understand your question. You basically want to change a pline with a width to be shown as a four sided closed polyline (see attachment).
I don't belive that is possible (unless others on here know how it can be done) a pline is effectively a single lline with a width so cannot be shown as a 4 sided object/closed polyline.
Regards
