AutoCAD 2010/2011/2012
jshih4914
Message 1 of 4 (4,041 Views)
Converting form Engineering to Architectural Scale
4041 Views, 3 Replies
04-26-2010 08:45 AM
I recieved drawing from France that are done in Metric system so when I copy paste them into my drawings the scle of things are totally off. Is there a way I can convert the original file to the standard foot and inches, size down the objects so when I paste them into my drawings they will be to the same sclae and proportion? Thanks!
*jg
Message 2 of 4 (4,041 Views)
Re: Converting form Engineering to Architectural Scale
04-26-2010 08:57 AM in reply to: jshih4914
Just remember that 25.4 mm = 1 inch. If they scaled 1 unit = 1 mm then
scale their drawings 1/25.4 to go to inches. If they scale 1 unit = 1
meter then scale their drawing 1000/25.4 to go to inches. Of course to
go to feet use 1/12 the multiplier =1/12*25.4 = 1/304.8
*A+P
Message 3 of 4 (4,041 Views)
04-26-2010 09:05 AM in reply to: jshih4914
Sure, if you want it as 1 unit = 1 inch
(typical for Architectural drawing units), then open the Metric
drawing:
If it's drawn 1 unit = 1 Meter, then scale
everything down by 0.0254
If it's drawn 1 unit = 1 mm, then scale everything
down by 25.4
Then start the Units command, change Insertion
Scale to Inches and save the drawing.
Note: Standard Metric drawing dimensions are not
the same as standard Imperial drawing dimensions ie.:
A typical single leaf door width in Metric is
900mm
A typical single leaf door width in Imperial
units is 36 inches
So converting 900 / 25.4 = 35.433 inches and not 36
inches
Paul
jshih4914
Message 4 of 4 (4,041 Views)
04-29-2010 08:52 AM in reply to: jshih4914
Ok thanks for all the help, I guess there is no easier way :smileyhappy:
Post to the Community
New Post
Need installation help?
