AutoCAD 2010/2011/2012
aguritzky
Message 1 of 15 (4,694 Views)
Converting Blended Surfaces To Solids?
4694 Views, 14 Replies
02-16-2011 09:07 PM
I have created an object using multiple surfaces some are revolved some are blended and would like to convert them to a solid object. I have tried surfsculp, surface offset, and thicken but none of them work. The surfaces do not create a watertight object but I do not understand why not, everything has been blended. When I try to offset it fails and when I use thicken it tells me that the object intersects itself. I do not know what to do can anyone help?
stevenelliott3894 wrote:
 Way to jump in there with unimportant criticism!
Unzip attached Part1.sat file.
Issue the acisin command.
http://au.autodesk.com/?nd=class&session_id=3056
Use the ACISIN command in AutoCAD to bring in a .sat (ACIS text) file.
Valued Mentor
stevenelliott3894
Message 2 of 15 (4,670 Views)
Re: Converting Blended Surfaces To Solids?
02-17-2011 08:11 AM in reply to: aguritzky
Unfortunately, AutoCAD cannot convert a surface to a solid like you wish. If you could manage to convert it to a closed mesh, then AutoCAD *might* be able to make it into a solid with CONVTOSOLID. This is an unfortunate situation that has been around since they started using solids technology (release 13), and they haven't seen fit to address this issue. Sorry.
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
aguritzky
Message 3 of 15 (4,666 Views)
02-17-2011 08:48 AM in reply to: aguritzky
Thank you for your response. I have tried to convert it into a mesh, when I do it becomes very ugly and rough and creates alot of holes even after using smooth mesh. I tried to patch the holes with the proper command (I cannot remember the name off the top of my head), but it actually just makes it worse.
I also have Inventor I am just not as familiar with it. Is there anyway I can import the drawing to Inventor and convert it into a solid? Or will I have the same issues?
Valued Mentor
stevenelliott3894
Message 4 of 15 (4,664 Views)
02-17-2011 08:52 AM in reply to: aguritzky
Sorry, I know very little about Inventor. There are many Inventor users here, so maybe one will chime in. Other than that, I would suggest downloading a demo of Inventor and trying things out for yourself, to determine if it can meet your needs.
Steven Elliott
JDMather
Message 5 of 15 (4,610 Views)
02-20-2011 06:26 PM in reply to: stevenelliott3894
... I would suggest downloading a demo of Inventor and trying things out for yourself....
uhhmm didn't the OP indicate already having Inventor?
Of course a question of this type of any complexity cannot possible be answered without a file.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Mentor
stevenelliott3894
Message 6 of 15 (4,588 Views)
02-21-2011 05:14 AM in reply to: JDMather
Uh... yes... yes, he did. I referred quickly back to his first post when I wrote that, but he didn't say it until his second post. Way to jump in there with unimportant criticism!
Steven Elliott
JDMather
Message 7 of 15 (4,569 Views)
02-21-2011 12:10 PM in reply to: stevenelliott3894
Valued Mentor
stevenelliott3894
Message 8 of 15 (4,566 Views)
02-21-2011 12:18 PM in reply to: JDMather
Is this supposed to convey a message to me?  :robotindifferent:
Steven Elliott
aguritzky
Message 9 of 15 (4,543 Views)
02-21-2011 02:09 PM in reply to: JDMather
Lol, I am staying out of this one. But thanks to everyone for the help it is appreciated.
aguritzky
Message 10 of 15 (4,531 Views)
02-21-2011 05:26 PM in reply to: JDMather
The part looks great in Inventor but I do not know how to get the file into AutoCAD?
