AutoCAD 2010/2011/2012
Active Member
buelentgms
Message 11 of 16 (935 Views)
Re: convert 3D volume to a solid (polygon mesh)
10-18-2012 06:53 AM in reply to: JDMather
hello, Solids (polygon mesh) should have 18 nodes. I need this solid for a FEM-program I do not know how to explain it! See the file: how can I convert the RED (3d volume) TO an object such as the GREEN ? when you look the properties / analyze the two objects you will see the difference of them. thx
JDMather
Message 12 of 16 (929 Views)
10-18-2012 07:57 AM in reply to: buelentgms
I do not see any attached images or files?
All of the FEM softwares I am familiar with do their own meshing within the FEM program.
(I use Autodesk Simulation (Algor), Autodesk Inventor, SolidWorks, and Creo Mechanica for analysis of solids.)
What software are you using that doesn't do meshing of the solid for you?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
buelentgms
Message 13 of 16 (920 Views)
10-18-2012 11:44 AM in reply to: buelentgms
sorry, here is the attachment..
I am using the SAP2000 for FEM and i can not import a 3d solid, which is created from primitives, like a box or a pyramid.
I can only import  "the polygon mesh", which is created with the command: 3dMESH, (which usually works with autolisp?)
And my aim is to convert the primitves to a polygon mesh, to avoid the programming with autolisp..
best regards
Active Member
yigit2124
Message 14 of 16 (783 Views)
12-15-2012 11:59 PM in reply to: buelentgms
I am wondering the answer of this thread, too.
Please add your answers if you have founded one until now.
Active Member
yigit2124
Message 15 of 16 (763 Views)
12-17-2012 12:46 AM in reply to: buelentgms
Is there someone to be interested in finding an answer to the question of this thread ?
I am desperate, waiting for your help !
Active Member
buelentgms
Message 16 of 16 (755 Views)
12-17-2012 04:23 AM in reply to: buelentgms
hey,
unfortunately I have no solution for this.. I'm still waiting for help!
thx
