AutoCAD Forum
Constraint issue
1 REPLY 1
davecollingwood
282 Views, 1 Reply
Constraint issue
Have had a quick search for the solution to this, but so far no joy.
I'm using AutoCAD 2011 to create a library of components for my company, which includes thousands of different sized doors and covers for electrical panels.
An option I'd like to include is a basic template block which uses a block-table (or lookup) to quickly choose the width and height required for an assembly. I know how to assign parameters, and have a working dynamic block which resizes as I'd expect.
The problem is that there are several other items in the block which need to move relatively to the overall size - for example, there is an inner polyline which is always 6mm from the outside edge, regardless of overall size. Maintaining the 6mm gap is not a problem using horizontal / vertical constraints, but when I choose a lower width or height from the block table, 2 of the edges are offset to the OUTSIDE of the main door, still by 6mm. (I have locked the lower left corner of both the outside edge and offset polyline to a particular position). So, how can I set up a constraint to say "this line must always be to a set side of this other line"? Is there a way to set it up to always be offset in a particaluar direction? Maybe I'm missing something obvious!
Thanks in advance!
Some of my greatest heroes wore eye-patches, there was Kirk Douglas... me on a Friday night... did I mention Kirk Douglas?
www.davecollingwood.com
1 REPLY 1
Hmm, seem to have solved it by using a block table rather than lookup - trying to run before I can walk I think!
”Boost
