AutoCAD 2010/2011/2012
Valued Contributor
4 Kudos
Post 1 of 5
common ribbontab in different partial cui
729 Views, 4 Replies
04-11-2012 05:10 AM
is this this possible?
I have a lot of tools with separate installers. But the ribbon-panales merge in one ribbon-tab.
regards
Mario
1,219 Kudos
Post 2 of 5
Re: common ribbontab in different partial cui
04-11-2012 05:16 AM in reply to: mario.rosenbohm
you got a lot of tools? ... from different vendors or from one vendor?
or you have some tools to distribute and need a solution for how such an installer should work?
- alfred -
Alfred NESWADBA
Valued Contributor
4 Kudos
Post 3 of 5
04-11-2012 05:59 AM in reply to: Alfred.NESWADBA
Hello alfred,
its round 6 tools with her own cui and installer.
Regardless of the panels will be installed all in the same tab.
regards
mario
Valued Contributor
4 Kudos
Post 4 of 5
04-11-2012 07:13 PM in reply to: mario.rosenbohm
it works, if you create a ribbon tab manually with the equal alias in the main-cuix.
Now...  How can i create a ribbon tab in the main-cuix with .net ?
Valued Contributor
4 Kudos
Post 5 of 5
04-11-2012 08:41 PM in reply to: mario.rosenbohm
here ist the "main-ribbontab-solution" in c#
        public static Boolean createMainRibbonTab(String tabName, String tabTitle, String tabId, IList<String> workspaces)
            Boolean result = false;
            String mainCuixName = Application.GetSystemVariable("MENUNAME") + ".cuix";
            Autodesk.AutoCAD.Customization.CustomizationSection maincuix = new Autodesk.AutoCAD.Customization.CustomizationSection(mainCuixName, false);
            Autodesk.AutoCAD.Customization.RibbonRoot acRibbonRoot = maincuix.MenuGroup.RibbonRoot;
            Autodesk.AutoCAD.Customization.RibbonTabSource acRibbonTabSource = acRibbonRoot.FindTabWithAlias(tabName.ToUpper());
            if (acRibbonTabSource == null)
                try
                    acRibbonTabSource = new Autodesk.AutoCAD.Customization.RibbonTabSource(acRibbonRoot);
                    acRibbonTabSource.Name = tabName;
                    acRibbonTabSource.Id = tabId;
                    acRibbonTabSource.Aliases.Add(tabName.ToUpper());
                    acRibbonTabSource.Text = tabTitle;
                    acRibbonRoot.RibbonTabSources.Add(acRibbonTabSource);
                    Autodesk.AutoCAD.Customization.WSRibbonTabSourceReference acRibbonTabSourceReference;
                    if (workspaces == null)
                        foreach (Autodesk.AutoCAD.Customization.Workspace item in maincuix.Workspaces)
                            acRibbonTabSourceReference = Autodesk.AutoCAD.Customization.WSRibbonTabSourceReference.Create(acRibbonTabSource);
                            acRibbonTabSourceReference.SetParent(item.WorkspaceRibbonRoot);
                            item.WorkspaceRibbonRoot.WorkspaceTabs.Add(acRibbonTabSourceReference);
                    else
                        foreach (String wsName in workspaces)
                            Autodesk.AutoCAD.Customization.Workspace acWorkSpace = maincuix.getWorkspace(wsName);
                            if (acWorkSpace != null)
                                acRibbonTabSourceReference.SetParent(acWorkSpace.WorkspaceRibbonRoot);
                                acWorkSpace.WorkspaceRibbonRoot.WorkspaceTabs.Add(acRibbonTabSourceReference);
                    maincuix.Save();
                    result = true;
                catch
            else
                result = true;
            return result;
