AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 3
Combine Two Drawings Into One
726 Views, 2 Replies
01-14-2013 09:47 AM
I need to have two people working in the same dwg, basically at the same time.  We call it an Assembly Plan.  Everything is done in model space.  I want to be able to have each of them basically work in the same dwg and at the end of the day, BOTH of their work is saved in one dwg, but no double lines, etc.
594 Kudos
Post 2 of 3
Re: Combine Two Drawings Into One
01-14-2013 10:21 AM in reply to: ebland_0724
1 will be read only.
Have 1 person Xref the main drawing, then later INSERT  in the main drawing.
If they overlapped, OVERKILL them.
15 Kudos
Post 3 of 3
01-14-2013 11:09 PM in reply to: ebland_0724
AutoCAD doesn't work on that way.even if you use xref,it will be useless.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
