AutoCAD Forum
Colors 1-9 appear as white. Colors 10-22 are wrong.
3 REPLIES 3
rafaelaustin
415 Views, 3 Replies
You can see in the attached screen cap that colors 1-9 appear as white on my screen and that colors 10-22 are not correct either. This is only occuring in one specific drawing.  Is there a preference that I switched somewhere that would make this happen? I have double checked that everything is ByLayer or ByColor that I can think of. If I insert this color chart into other drawings it looks fine. using C3D 2012.
I would just restart my drawing, however it is the new company template file that I have invested many hours into and would really like to be able to keep working with it and not start over.  Or is there a good way to import and overwrite all the Prospector settings into a blank drawing?
Thanks in advance!
Rafael
3 REPLIES 3
pendean
in reply to: rafaelaustin
PAGESETUP command, uncheck the box under the plot style table pull down that us designed to display it all the time.
rafaelaustin
in reply to: pendean
Thanks! That was it.
rkmcswain
Ugh....starting to see a lot more of these posts....
Maybe a little proactive thought is needed here....? Like an in-canvas "display plot styles" toggle in a layout similar to the in-canvas UCS and Visual Style controls in MS?
R.K. McSwain     | CADpanacea | on twitter
”Boost
