iam using Civil 3d 2013
when i try to start civil 3d an error message appears :
FATAL ERROR : unhandled access violation reading 0xffffffff exception at f20a241eh
i tried "repair" and "reinstall" and it is still crashing on startup
please help
thank you
Solved by braudpat. Go to Solution.
i dont know what changed with my setup , what do you mean ?
you can find attached pc specs and os
thank you
Hello
Just an idea, could you install the SP 2 for CIVIL 2013 :
Then launch CIVIL 2013 + SP 2 ...
... If OK ... please could you open your DWGs in RECOVER Mode and then Re-Save with an OTHER Name and then TEST ...
Please NEVER rewrite the original filename !!
Patrice BRAUD
Hello
You are happy ... I am happy ...
So OK , please mark "Accept as Solution" and/or Kudos gladly accepted ...
Patrice BRAUD
