AutoCAD Forum
civil 3d crashes on startup
6 REPLIES 6
mikecharbel
716 Views, 6 Replies
iam using Civil 3d 2013
when i try to start civil 3d an error message appears :
FATAL ERROR : unhandled access violation reading 0xffffffff exception at f20a241eh
i tried "repair" and "reinstall" and it is still crashing on startup
please help
thank you
6 REPLIES 6
pendean
in reply to: mikecharbel
Error message means nothing sadly: did this just start? What changed with your setup? What is your PC specs and OS?
mikecharbel
in reply to: pendean
i dont know what changed with my setup , what do you mean ?
you can find attached pc specs and os
thank you
braudpat
Hello
Just an idea, could you install the SP 2 for CIVIL 2013 :
http://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autocad-civi...
Then launch CIVIL 2013 + SP 2 ...
... If OK ... please could you open your DWGs in RECOVER Mode and then Re-Save with an OTHER Name and then TEST ...
Please NEVER rewrite the original filename !!
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
mikecharbel
in reply to: braudpat
yesss that works
thank you very much 🙂
braudpat
Hello
You are happy ... I am happy ...
So OK , please mark "Accept as Solution" and/or Kudos gladly accepted ...
Patrice BRAUD
mikecharbel
sure 🙂
thank you again
”Boost
