AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 5
Changing Units on a existing drawing
1437 Views, 4 Replies
04-04-2012 08:27 AM
I have a venue drawing that is in mm and I need to convert it to ft/inch so I can update and get dimensions from it.  Can this be done so when I change the format in drawing units it will update the drawing units?
Current settings.
Drawing units
Length:
Type - Decimal
Percisin - 0
Angle:
Type - Decimal Degrees
Precision - 0
Insertion Scale:
Unitless
*Expert Elite*
601 Kudos
Post 2 of 5
Re: Changing Units on a existing drawing
04-04-2012 08:40 AM in reply to: Brett_2000
Your drawing doesn't know it's mm or inches, km.... it only knows one thing length, so you have to scale the drawing,
or you can leave it as it is and add dimension factor to it.
New Member
0 Kudos
Post 3 of 5
04-04-2012 08:51 AM in reply to: Patchy
How would I do that?
*Expert Elite*
601 Kudos
Post 4 of 5
04-04-2012 09:24 AM in reply to: Brett_2000
Like this
5 Kudos
Post 5 of 5
04-05-2012 01:48 PM in reply to: Patchy
Create a toolbar with a button. Use the following as the buttom command.
^C^C-dwgunits;2;2;4;no;no;no;^C^C(IF (NOT C:smileyfrustrated:CALE-LIST)(LOAD "SCALE-LIST"));SCALELISTREM;SCALELISTIMP;
the attached lisp is needed!!
Cad Blog:
http://geauxcad.wordpress.com/
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
