I'm using 2012 ADT and I have a file with 922 attributed blocks, all the same block but each has different text in them.
Each block has (2) lines of text/attributes in them.
All of the attributes are the same text style and font height.
What I would like to do is change only the text style in all of the attributes.
No other change would be involved.
Maybe if I Pulled the block into a new file and bring it in as a updated block?
Would that work?
Although I have to admit I'm not sure how updating blocks works with the newer versions of CAD.
So I went searching the forum more and ended up finding information about the "battman".
A command that I had never used or even heard of until today.
So I went and typed it in, messed around with it for a few minutes and figured out that I can globally change all of the attributed blocks of the same name at one time!
All 922 blocks have now been updated.
So I can still give kudos to the board for giving me the answer I needed.
