AutoCAD 2010/2011/2012
Active Contributor
nxt925
Message 1 of 3 (295 Views)
Changing Dimstyle
295 Views, 2 Replies
08-09-2012 04:26 PM
I just got a new job with AutoCAD 2011. In the previous version (was using 2008 beore), I could select all lines, dimensinos hatches, and then change the dimension style. But with this new version, as soon as I select anything that is not a dimension, like a hatch pattern or a regular line, I can't change the dimension style anymore. Is there anyway to change this back to how it was?
Valued Contributor
MatthewB80097
Message 2 of 3 (272 Views)
Re: Changing Dimstyle
08-10-2012 03:50 AM in reply to: nxt925
In properties is there not a drop down list which seperates all the items which you have selected? You can then select the dimensions by type individually. I tend to have properties open all the time but anchored to flash on when I hover over the tab.
Active Contributor
nxt925
Message 3 of 3 (257 Views)
08-10-2012 09:22 PM in reply to: MatthewB80097
I figured it out. I noticed that when the dimension tab in the Ribbon is there, when I select all objects and try to change the dimension the option is grayed out. But if I have the dimension toolbar (classic mode), I can select all objects regardless if it's a hatch line or dimension and change the dimension style perfectly fine. Weird, but it works.
