AutoCAD 2010/2011/2012
oamaya
Message 1 of 18 (42,256 Views)
Accepted Solution
changing block names
42256 Views, 17 Replies
03-23-2011 09:00 AM
Is it possible to edit a block name?  The alternate solution is to create a new block (door) to accurate describe sizing/ type and copy to and delete old blocks w/ innacurate names.  Because of the high number of doors, the alternate solution would take much longer.  Thanks.:smileyhappy:
REN
*Pro
Modman_4
Message 2 of 18 (42,253 Views)
Re: changing block names
03-23-2011 09:29 AM in reply to: oamaya
REN
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
oamaya
Message 3 of 18 (42,250 Views)
03-23-2011 09:45 AM in reply to: Modman_4
I didn't receive any info...
Johneng
Message 4 of 18 (42,245 Views)
03-23-2011 09:50 AM in reply to: oamaya
REN is the keyboard shortcut for the RENAME command.
oamaya
Message 5 of 18 (42,242 Views)
03-23-2011 09:53 AM in reply to: oamaya
Got it. That did it.  Thank you much!
igi_pop
Message 6 of 18 (41,866 Views)
11-03-2011 02:49 AM in reply to: Modman_4
Modman_4 wrote:
REN
big up man! i've been workin in CAD and Civil for ages now and that little thingie bugged me VERY MUCH :smileyhappy:
Custom build
Phenom 9950BE quad
windows 7 x64
8GB RAM
Radeon 4800 512MB
New Member
mstun
Message 7 of 18 (37,257 Views)
11-11-2012 05:52 PM in reply to: Johneng
when i typed "ren"
Command: ren
RENAME
** RENAME command not allowed in block editor. **"
any cmt that i can edit on block name please :robothappy:
*Expert Elite*
Alfred.NESWADBA
Message 8 of 18 (37,252 Views)
11-11-2012 10:15 PM in reply to: mstun
why is it necessary to change any blockname within the blockeditor?
If you want to save your currently opened blockdefinition (currently open within the blockeditor) than you can't rename it, but you can use _BSAVEAS to save this definition with a new name.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
New Member
jonli011
Message 9 of 18 (36,706 Views)
11-27-2012 06:35 AM in reply to: oamaya
You cant rename blocks when you're in the blockeditor.
So close it and try again
New Member
cbingaman110
Message 10 of 18 (36,542 Views)
11-30-2012 11:51 AM in reply to: oamaya
I have a similar issue.
I am trying to change the color of a 3D Semi Truck which in itself contains 12 blocks that make up the Semi.
I need to change the name of "CHASSIS" becuase when i edit the Semi Block, and insert it into my main drawing, the changed color of the "CHASSIS" and all the other 11 blocks, it gives the "duplicate block definition ignored" because i have the original Semi with the original color in the same drawing. I need 2 different colors.
So, if I can change the name of the "sub" blocks of the semi, It will not give the duplicate error and will show as a different color.
If anyone has had this issue, Id appreciate some advise.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
