AutoCAD 2010/2011/2012
Active Member
LukeLans
Message 1 of 10 (2,062 Views)
Change Text Case
2062 Views, 9 Replies
07-20-2011 06:19 AM
Hi all,
Where has the global change text case gone?!! It used to be in express tools, if I remember....is there a way to get this command into 2012?
Thanks in advance.
Patchy
Message 2 of 10 (2,060 Views)
Re: Change Text Case
07-20-2011 06:25 AM in reply to: LukeLans
Tcase command, if it doesn't run, install Express
Active Member
LukeLans
Message 3 of 10 (2,052 Views)
07-20-2011 07:08 AM in reply to: LukeLans
THANKS! All done.
Active Member
AndyKuang
Message 4 of 10 (1,936 Views)
11-16-2011 06:43 PM in reply to: Patchy
It doesn't work for me, even I reinstall Express, but txt2mtxt works for my AutoCAD 2012.
Any other solution?
Patchy
Message 5 of 10 (1,932 Views)
11-16-2011 08:17 PM in reply to: AndyKuang
Search for TCASE.LSP in your PC, if it can be found, use APPLOAD to load it then use it.
Active Member
AndyKuang
Message 6 of 10 (1,927 Views)
11-16-2011 08:30 PM in reply to: Patchy
Thanks for you hint.
I found the TCASE.LSP  in my Computer, how can I use APPLOAD to load it ?
Patchy
Message 7 of 10 (1,922 Views)
11-16-2011 08:47 PM in reply to: AndyKuang
Type in APPLOAD, click until you find it, click on LOAD
then type in TCASE
(Add it to your Startup Suite so it can be available anytime)
Active Member
AndyKuang
Message 8 of 10 (1,891 Views)
11-17-2011 12:34 PM in reply to: Patchy
Thanks for your help.
It still not working, here is the message form AutoCAD "tcase ; error: no function definition: ACET-ERROR-INIT".
I use the APPLOAD and load the " TCASE" and add it to my Startup Suite .
But when I have a look at the " Loaded applications", the "tcase.lsp" in grey colour.
Any other solition?
Thanks again.
Andy
Patchy
Message 9 of 10 (1,888 Views)
11-17-2011 12:38 PM in reply to: AndyKuang
Add a path to the Express folder in OPTIONS, restart autocad.
Active Member
AndyKuang
Message 10 of 10 (1,873 Views)
11-17-2011 02:43 PM in reply to: Patchy
Thanks lot, it works for now.
Andy
