AutoCAD 2010/2011/2012
Valued Contributor
rbt1053
Message 1 of 7 (3,423 Views)
change startup page template
3423 Views, 6 Replies
07-16-2011 05:07 PM
Is this do-able?
I would like to have Acad open to a template file of mine instead of the generic default one. I've looked into STARTUP and it's values, QNEW, and the Options>Files>Drawing Templates.
What I'm looking for is a setting which allows me to have my template sheet open on startup but still have QNEW open up the Select a Template dialog box. In other words, is there a way to substitute my template for the generic one while still having the  QNEW  button open the dialog box?
I guess Im looking for something between STARTUP 0 and QNEW.
pendean
Message 2 of 7 (3,416 Views)
Re: change startup page template
07-16-2011 08:24 PM in reply to: rbt1053
Just have your startup sortcut open your template file: two ways to do it:
1. Old-School, create a shortcut in WIndows Explorer of royur template file and double-click on it when you need to start with a template.
2. Edit the 'normal' AutoCAD shortcut to start with your template: read THIS PAGE
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
rbt1053
Message 3 of 7 (3,392 Views)
07-17-2011 12:48 PM in reply to: pendean
This what I ended up doing. First tried the #2 solution but couldn't get it working. Then tried the obvious which worked:
The default opening page at startup is based on the acad.dwt template  in the Templates folder. I simply renamed my template which I wanted to use as the default start page to acad.dwt and it worked like a charm. Almost too easy.
Murph
Message 4 of 7 (3,387 Views)
07-17-2011 01:42 PM in reply to: rbt1053
Just make sure you create a backup copy of "your" acad.dwt so when you install an update or repair/reinstall you can repeat the procedure
Murph
Supportting the troops daily.
Valued Contributor
rbt1053
Message 5 of 7 (3,383 Views)
07-17-2011 02:31 PM in reply to: Murph
Thank you all for your help.
sandhup
Message 6 of 7 (2,668 Views)
09-12-2012 08:07 AM in reply to: rbt1053
Thanks for this, was tearing my hair out looking for a way so that drawing1.dwg would open in metric on start up. Many thanks.:smileyvery-happy:
Norrisc761
Message 7 of 7 (2,655 Views)
09-13-2012 06:06 AM in reply to: sandhup
Can't you just change the Template Settings in the Files tab of the Options dialog box?
