AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Catalog file cannot be loaded...
2 REPLIES 2
1177 Views, 2 Replies
I'm using the 2010 AutoCAD Architecture tutorials, but with 68x ACA12 on a HP Pavilion G series
My Content Browser is completely empty and when I try to search for components used in the tutorials I get:
"The catalog you are trying to acces: C:\Users\Steph\AppData\Local\..\CBSearch-1.atc cannot be loaded or is not in the correct file format."
What should I do? Is there a specifc catalog that comes with the earlier version, or with the tutorials that I need? Or is there an install problem?
I'd really appreciate any help! 🙂
Steph
Tags (1)
2 REPLIES 2
Marco.DelcarmeQ7WRT
I am having the same issue, I cannot find a fix anywhere...
So you are still using AutocADARCH2010 too?
If not, reset the ARCH program first and see if the issue is resolved. If not, uninstall/reinstall and this time AVOID migrating from an older version, see if your issue goes away.
”Boost
