AutoCAD 2010/2011/2012
Distinguished Contributor
rhots
Message 1 of 7 (620 Views)
cannot use properties box to scale x y and z independantly
620 Views, 6 Replies
01-03-2013 12:09 PM
Mirrored blocks with annotative attributes, I know I can scale each one individually, but there are over one hundred. It would be nice to use the properties box and type in the scale. As soon as I type in the "x" scale, y and z follow! I need to put in negatives in x only.
Why do y and z automatically follow x?!?!?
Rick
Rhots,
Alfred has it right. Try this.
  1. Initiate the BLOCK command.
  2. Find your block in the Name list box.
  3. Under Behavior, uncheck Annotative then uncheck Scale uniformly
  4. Click OK and allow AutoCAD to redefine the block
  5. Use ATTSYNC to update the block insertions
  6. Select all of the blocks
  7. Use the properties editor to edit the x, y , and z scales independently.
heinsite
Message 2 of 7 (553 Views)
Re: cannot use properties box to scale x y and z independantly
01-06-2013 05:26 PM in reply to: rhots
The "Scale Uniformly" block was checked in the block definition.  You'll need to redefine the block without that requirement.
Dave.
Dave Hein, P.E.
Alfred.NESWADBA
Message 3 of 7 (544 Views)
01-07-2013 01:20 AM in reply to: rhots
the options "Annotative = yes" and "Scale uniformly = no" can't be combined in that way.
If it's annotative, then it has to be uniformly scaled.
So either uncheck Annotative too or define a new block with another aspect ratio and use that when you need it.
- alfred -
Alfred NESWADBA
Product Support
Steve_Bessette
Message 4 of 7 (515 Views)
01-08-2013 06:17 AM in reply to: Alfred.NESWADBA
Just checking to see if the above suggestions have resolved your inquiry.  If they have, please check "Accept as Solution".  If not, please let us know so we can further assist.
Steve Bessette
Support Specialist
Product Support
rhots
Message 5 of 7 (511 Views)
01-08-2013 06:28 AM in reply to: rhots
No, I (adt2010) do not have the capability to adjust yes or no for annotative, and I do not see "scale uniformly'
when I "bedit' the block the definitions are NOT annotative. but the block is annotative
see attachment
Active Contributor
W2CAD
Message 6 of 7 (494 Views)
Re: cannot use properties box to scale x y and z independently
01-08-2013 12:45 PM in reply to: rhots
Rhots,
Autodesk AutoCAD 2014 Certified Professional
heinsite
Message 7 of 7 (481 Views)
01-08-2013 03:41 PM in reply to: W2CAD
You're on a roll today with Block problem solutions!  :smileywink:
Dave
Dave Hein, P.E.
