AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 5
cannot draw vertical lines or rectangles in front, back and sides view
1719 Views, 4 Replies
10-25-2011 04:02 AM
On previous versions of autocad I used all views to draw lines and rectangles to produce 3d models, but now when i try it they only come up as horizontal lines.
*Expert Elite*
594 Kudos
Post 2 of 5
Re: cannot draw vertical lines or rectangles in front, back and sides view
10-25-2011 04:31 AM in reply to: stevo_08
Which previous versions can do that?
set it to e.g. SE view, you can,  but not front view.
New Member
0 Kudos
Post 3 of 5
10-25-2011 04:50 AM in reply to: stevo_08
2004 could do it. I was able to draw in all views, extrude the parts (walls, windows etc.), then join them together using an angled view
*Expert Elite*
594 Kudos
Post 4 of 5
10-25-2011 06:18 AM in reply to: stevo_08
But if you look at front , back.... whatever view UCS icon, it only gives you x and y but no Z
*Expert Elite*
213 Kudos
Post 5 of 5
10-25-2011 07:19 AM in reply to: stevo_08
In your example look at the UCS, the X and Z are showing, change to an iso view or change the UCS so the X and Y show.
When drawing 3D in AutoCAD it is best to have at least three viewports showing, with one of them in an iso view and the others in a front and right view, or top, etc. so you know for sure where you are drawing in space.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Post to the Community
New Post
