I am trying to use the DIVIDE command but can't see the points (nodes) it creates after the command is complete. I have the OSNAP setting on to snap to nodes which I can't even see. The QSELECT command let me see that they are indeed in the drawing, and that is the only way I can select them.
Solved by Patchy. Go to Solution.
DDPTYPE command and select the point style and size.
and don't use DEFPOINTS layer if you do.
