AutoCAD 2010/2011/2012
Distinguished Contributor
Andrew_K99
Message 1 of 6 (1,346 Views)
Can't remove 'Legend' font style or table style ?!?
1346 Views, 5 Replies
11-05-2009 02:03 PM
I have run across a very annoying issue that has stumped me.
There is a font and table style called "Legend" that is automatically generating and can not be purged.
I have looked through all the start up files, all the lisp files and can't find anything that would be creating them!
They appear in any file I open, new or old and even if I open a template file.
I have attached a file that should be empty but you will (or should) see both a font and table style called "Legend".
Anyone have any suggestions?
(FYI I am running AutoCAD Civil 3D 2010 as AutoCAD 2010)
Andrew
*Jason Piercey
Message 2 of 6 (1,345 Views)
Re: Can't remove 'Legend' font style or table style ?!?
11-05-2009 02:23 PM in reply to: Andrew_K99
I opened your file and was able to purge the tablestyle. After purging the
tablestyle I was able to purge the textstyle. I did nothing more than open
the file (AutoCAD 2010)
wrote in message news:6284517@discussion.autodesk.com...
Andrew
Andrew_K99
Message 3 of 6 (1,345 Views)
11-06-2009 01:20 PM in reply to: Andrew_K99
Anyone have any clue as to why this is happening?
*Murph
Message 4 of 6 (1,345 Views)
11-06-2009 05:12 PM in reply to: Andrew_K99
Because the Civil3D is build on top of Map3D and those styles are required
for the legend tools to work, that it is build into the "new" command of the
program would be my guess. Even opening a Vanilla AutoCAD dwt in C3D/Map3D
will add them. (and not let you delete them)
Murph
http://map3d.wordpress.com/
"Andrew_K99" wrote in message news:6285084@discussion.autodesk.com...
New Member
AMGAUDET
Message 5 of 6 (1,244 Views)
10-04-2010 05:22 AM in reply to: Andrew_K99
Ran into the same problem.  Client wanted all unused items purged from drawing. Could not purge table style "Legend" and text style "Legend"
Solution
Use "rename " command and rename table style "legend" to another name (anything).  It can then be purged and the text style "legend" as well.
Active Member
Hammerling
Message 6 of 6 (670 Views)
11-27-2012 12:29 PM in reply to: Andrew_K99
Found this on another site posed by someone named "aewatson" 8th Jun 2011, 12:54 am
    Here is how you can delete both the 'Legend' table style and textstyle:
    - Type TABLESTYLE
    - Right-click and rename 'Legend' to something else.
    - Close the dialog box.
    - Retype TABLESTYLE
    - Delete the renamed table style
    - Delete the text style (now that it is no longer referenced)
This worked for me.
Gerald
Post to the Community
New Post
Need installation help?
