AutoCAD 2010/2011/2012
Valued Contributor
rbt1053
Message 1 of 7 (13,067 Views)
can I turn off the wcs / ucs icon on the upper right hand side ofmy screen?
13067 Views, 6 Replies
06-30-2011 04:37 PM
There's got to be a way...I just haven't  been able to find it yet.
I don't need/use the wcs/ucs icon, and also find annoying the wcs icon at the upper right hand corner of my screen (annoying...(yes this isn't a major problem in my life...I'd just like to remove it.
So, s there a way, by default, to turn off the icon?  If not is there a way to turn off the icon on an idividual sheet and then use that sheet as a templete file sheet?
Nothing personal with the icon....I just don't need it and would to delete it on my system until I find that I need it.
Have you right-clicked it yet?
Just kill the UCS bit? Right click the ViewCube, pick ViewCube Settings... and turn off the Show UCS menu toggle.
Lose the whole ViewCube? See the ViewCube section of this blog post: http://www.blog.cadnauseam.com/2011/04/14/autocad-2012-putting-things-back-to-normal/
pendean
Message 2 of 7 (13,065 Views)
Re: can I turn off the wcs / ucs icon on the upper right hand side ofmy screen?
06-30-2011 05:22 PM in reply to: rbt1053
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Steve_Johnson
Message 3 of 7 (13,057 Views)
06-30-2011 09:01 PM in reply to: rbt1053
Steve Johnson - blog nauseam - ClassicArray
Valued Contributor
rbt1053
Message 4 of 7 (13,039 Views)
07-01-2011 05:47 AM in reply to: Steve_Johnson
Thank you both for your help.
New Member
benjdk
Message 5 of 7 (12,620 Views)
11-04-2011 05:34 AM in reply to: rbt1053
"navvcube" will bring up otions [on/off/settings]
New Member
dhav
Message 6 of 7 (1,970 Views)
07-21-2014 10:15 PM in reply to: benjdk
thanks this command working.........
Valued Mentor
KLYPHY
Message 7 of 7 (1,906 Views)
07-24-2014 06:47 AM in reply to: rbt1053
AutoCAD usually has several places to go to accomplish most anything.
For the View Cube, at the top of your screen, click "View".
Then near the right, click "User Interface".
Click on "View Cube" to add or remove from your screen.
Read Y'all Later -KLYPH
