I'm really hoping that someone could help me with the screw-up I just made.
I was dimensioning a viewport and has gone a good deal w/o checking when I eventually recognized that I've been doing this in a paper space instead of the model space (or the viewport itself.) And it's a lot of work, take a look:
So I'm curious if someone could suggest if there's an easy way to move all those dimensions into the model space? Or is it simpler to redo it from scratch?
+1
Here's the HELP link for CHSPACE http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-4d13...
and a Hip Tip on Changing Spaces by Lynn Allen http://lynn.blogs.com/lynn_allens_blog/2008/10/an-autocad-hip.html
Thanks. I tried and CHSPACE made them all disappear.
I found a solution though. Here it is if someone is interested:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Change-...
Just remember when you use CHSPACE the scale of the dimensions stays 1:1. If they seem like they disappear, that is because the text and arrows/slashes are very small. You will have to change them to a dimstyle which supports the scale of the viewport you are working in.
