Can you break a leader line that runs thru a dimensions line and not using the wipeout command?
Solved by steve216586. Go to Solution.
2013 has the DIMBREAK command. I'm not sure if it existed in previous versions. Give it a shot and let us know.
Make sure you use the MLEADER command and not the QLEADER command with DIMBREAK.
