AutoCAD Forum
Break a leader line
6 REPLIES 6
falconbird1
12319 Views, 6 Replies
Break a leader line
Can you break a leader line that runs thru a dimensions line and not using the wipeout command?
6 REPLIES 6
Patchy
in reply to: falconbird1
Try DIMBREAK
dmfrazier
2013 has the DIMBREAK command.  I'm not sure if it existed in previous versions.  Give it a shot and let us know.
pendean
in reply to: dmfrazier
DIMBREAK has been around for a lot longer than R2013.
dmfrazier
in reply to: pendean
Terrific! I'm sure the OP will be delighted to know that!
steve216586
Make sure you use the MLEADER command and not the QLEADER command with DIMBREAK.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
falconbird1
in reply to: steve216586
thank you for all your help.
”Boost
