I made a drawing of several symbols tobeconverted into blocks. The first symbol was great. Subsequent symbols appeared to be scaled somewhere X100 when I tried to insert them. I reviewed what Icould and could not nail down athe problem and correct it. What did I do wrong?
What units are your block using? Are the same as the drawing.
eg. If your block is using inches as it's units and the drawing is using millimetres the block will be 25.4 times bigger.
Howard Walker
Can you post the offending drawing.
Also do the following
Click on TOOLS
Click on OPTIONS
Choose the tab which says USER PREFERENCES
On the left you will see INSERTION SCALE.
What are the two settings there. Change them to UNITLESS to be on the safe side, and then try inserting your block again.
Howard Walker
