I have a block (room info) that has five line os text with attributes that display grips which allow them to be moved in whatever drawing I put them in. Within that block there is a little polyline that is the square with a dash through it to represent sq. ft. that I made into a seperate block ( sq ft tick). The room info block part of it works great in all my drawings, but the darn sq ft tick block within the room info block won't budge! I have tried giving it a seperate insertion point and giving that block its own attribute, but no luck.
Is there any way to have a block within a block that has the same ability to move around as the other elements?
@sequeirs wrote:I have a block (room info) that has five line os text with attributes that display grips which allow them to be moved in whatever drawing I put them in. Within that block there is a little polyline that is the square with a dash through it to represent sq. ft. that I made into a seperate block ( sq ft tick). The room info block part of it works great in all my drawings, but the darn sq ft tick block within the room info block won't budge! I have tried giving it a seperate insertion point and giving that block its own attribute, but no luck.
If you made the block dynamic and used a MOVE parameter on the nested block, you could certainly move it like that, however I think you may be better finding a way to make your sq ft tick another attribute, or better yet include it one of the existing attributes (one of which is square feet, right?)
