I have a block that has trouble with the preview image that comes up as a thumbnail on the right column in design center. The image always just shows a dot, instead of the correct image. I have tried going into the file I'm pulling the block from and using _blockicon, but no luck. I tried going into the file I'm pulling the block from and zooming to extents and selecting all to see if maybe there was some stray mark that the computer might be trying to use as the preview. Again, no luck. What else could I try to fix the problem? (this was previously posted but I have re-posted so I could include the referenced file.
The "Weather Proof" visibility is using MTEXT with dynamic columns enabled and a defined width of 18.7291 which is causing the preview to include the defined width of the column. Turn off Dynamic Columns for that MTEXT object (WP), and change the defined width to zero using the Properties Palette within the block editor. (or just change the "WP" MTEXT to TEXT, like the other 4 text objects)
Here's a video demo. http://www.screencast.com/t/eHvsatdf
If you have other blocks with similar problem, I would check them to see if they also contain MTEXT object(s) that have defined widths much wider than needed.
(BTW, I used a "Classic" workspace to make the demo, so if you're using the Ribbon, your Block editor will look a bit different but you should still be able to find the equivalent tools)
