AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 1
Block Authoring Tool Palette Not Working
442 Views, 0 Replies
10-26-2010 02:47 PM
I 'v recently installed AutoCAD 2010 and in the block editor, the block authoring tool palette gives me the message "unable to execute tool. The specified procedure could not be found." The pull down commands do work so there is a workaround, but I do prefer the commands from the palette. Does anyone know how to fix this problem? is there a variable?
I tried copying the commands/tools to the block editor tool palette but was unable to do that as well, since AutoCAD does not allow that inside of the block editor.
Post to the Community
New Post
