I discover synchronizing the attribute block does not work. Say I want to change the value E16 to E16a in block editor and after synchronizing the attribute does not change. What worse is that if I erase one attribute E16, then synchronize, the other attribute value (E18, E8) change to a different number (E16, E18*) . Attached is an example dwg.
Solved by nickdoos. Go to Solution.
I found a solution. Simply rename the tag. All the attributes share the same tag name which caused the problem. When I rename tag ie littra1, littra2 for each attribute then less ****-up to synchronising the values
Yes that is the correct way to define Attributes in a Block. ALL Tags must be unique
Also if the Block is Dynamic the Attribs will need to be Locked as well.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
